Hello-
VDJ will only recognize the timecode signal from my CDJs for about 5 seconds on startup. After that, there is no signal. Timecode control functions flawlessly (with proper sound output), and even shows in the timecode setup window- but just for a few seconds. I've tried control tone via CD and USB, with the same results.
I believe I have everything setup correctly:
Pioneer utility outputs set to "Control Tone (LINE)"
VDJ outputs and timecode configured to corresponding decks.
I'm not a Serato user, but ran timecode as a test, and everything functioned perfectly.
geposted Tue 24 Oct 17 @ 2:10 am
Anyone?
geposted Fri 10 Nov 17 @ 12:42 am
Can you post here screenshots of the Pioneer Utilities (Inputs and Outputs) and your VDJ Audio Setup ?
geposted Fri 10 Nov 17 @ 8:03 am
