I'm selling on my Stanton DJC.4 which came with Virtual DJ LE. Unfortunately I've lost the disc for the LE software (Never needed it since I owned full version) Is there anywhere I can download a copy of LE using the serial number of the unit? Thanks in advance
geposted Wed 25 Oct 17 @ 5:46 pm
You would need to know the serial number then register it. That then makes it non-transferrable.
This is from the wiki:
If you have lost your serial number for VirtualDJ LE or DJ Console Edition that came with your DJ Console or other MIDI controller, then you may be able to retrieve it by contacting the manufacturer who can look it up in their records. Unfortunately, we cannot retrieve serial numbers for VirtualDJ LE that have not been registered with us because we have no record of them until they are registered. These serial numbers are issued by the manufacturer.
geposted Wed 25 Oct 17 @ 5:56 pm
if you never registered the LE serial in your account and have that serial number handy (somewhere), you can have the person who is buying the unit register it in his account, then he can download VDJ LE.
If you don't have the serial, you can contact Stanton and tell them you lost your CD & serial.
If you have registered it, then its not transferable.
geposted Wed 25 Oct 17 @ 5:57 pm
Hie l lost a disc and serial number for virtual dj led 7 for Gemini G2v
geposted Wed 12 Sep 18 @ 7:11 pm
Please read this thread in it's entirety, you will find your answer.
geposted Wed 12 Sep 18 @ 7:33 pm
