Hi.
Is there any way to play/stop/load playlist in a virtual DJ on desired time for specific days? I see there was an addon called SBDJ Scheduler, but for version 6.
Thank you
Br,
Dali
Thank you
Br,
Dali
geposted Tue 31 Oct 17 @ 8:49 am
I could execute and terminate the VirtualDJ process (Vitrualdj8.exe) using a task scheduler, but the I would need to load automix and start playback on load.
Any ideas?
Thank you
Br,
Dali
Any ideas?
Thank you
Br,
Dali
geposted Tue 31 Oct 17 @ 9:22 am
VirtualDJ is software for playing out live in general.
You are probably better to look at some sort of radio automation software in this instance.
geposted Tue 31 Oct 17 @ 9:26 am
It is possible to write a plugin that sends a vdjscript command to vdj at specific times.
The command to use is playlist_load, which you can add the name of your playlist to.
geposted Tue 31 Oct 17 @ 9:37 am
Solved.
NirCMD.exe will send shortcuts (or mouse clicks) for AUTOMIX toggle, triggered by Windows Task Scheduler.
Simple :)
Example of the batch file:
REM ----- RUN VIRUTAL DJ
start "VirtualDJ" "c:\Program Files (x86)\VirtualDJ\virtualdj8.exe"
REM ----- WAIT FOTR THE APP TO LOAD
Timeout 5
REM ----- ACTIVATE WINDOW
nircmd win activate title "VirtualDJ"
REM ----- MOUSE ACTIONS
REM nircmd setcursor 1850 580
REM nircmd movecursor 10 10
REM nircmd sendmouse left click
REM ----- SEND Shortcut
nircmd sendkeypress ctrl+spc
Br,
Dali
Simple :)
Timeout 5
Br,
Dali
geposted Tue 31 Oct 17 @ 10:42 am
