I'd like to map a key to set master tempo to 0, the master_tempo function doesn't seem to do that.
geposted Sun 05 Nov 17 @ 3:03 pm
Your post is ambiguous. Do you want to reset the key of the track, or to reset the pitch (playback speed) to zero?
The master_tempo command is similar to key_lock and is nothing to do with pitch.
geposted Sun 05 Nov 17 @ 3:31 pm
pitch to 0
geposted Sun 05 Nov 17 @ 3:59 pm
"pitch 100%" will make the deck jump straight to 0
"pitch_reset" will do it gradually (you can add a number to change the tempo for the gradual change)
geposted Sun 05 Nov 17 @ 4:26 pm
There's also a config option to reset the pitch automatically whenever you load a track.
geposted Sun 05 Nov 17 @ 4:34 pm
thank you!
geposted Sun 05 Nov 17 @ 5:13 pm
