Hi there,
im trying to delete some tracks from my library AND disk (network drive). When i select the tracks, right click --> file operations -> delete, nothing happens. Am i misunderstanding the function? I expect that it should delete these files?
Using the newest VDJ with Mac OS X High Sierra
Greetings,
Mexyn
Greetings,
Mexyn
geposted Sun 05 Nov 17 @ 11:25 pm
          do you have the correct File Permission to delete files on this network drive?
if it doesn't work outside VDJ it will not work inside VDJ.
geposted Mon 06 Nov 17 @ 12:40 am
          As wickedmix said, you must ensure you have the rights to delete files on the NAS itself.
What I would like to add though is that there's another case that "Delete" a single file may fail:
If that file is still open on prelisten player.
Other than that, file operations work perfectly on both Windows and MAC OS X
geposted Mon 06 Nov 17 @ 8:32 am
Well, I can delete them via Finder. But its definitely an issue with the NAS Drive, as the delete Function works with local stored files. I just dont get what it is...the drive is mounted via SMB. When i mount the drive initially (after reboot for example), then i have to enter my login and password of the NAS to be able to mount it. AFTER that, it appears in Finder as mounted drive and i can access it in VDJ too. In Finder i can delete files (without entering any login/pw again), so i would expect it should work in VDJ too, but it doesnt. Do i miss something?
geposted Mon 06 Nov 17 @ 10:41 am
