Hello
I am using Traktor Pro which I like very much, but the following would make it damn perfect!
I would like to see a control function that can be programmed for a midi controller and / or a button on the graphics interface that will switch to the next track in cruise mode, a sort of "mix now" button, it is cumbersome to have to pull the faders.
I would like to see a similar function to the auto gain which stores a gain setting for normalizing a playlist applied to master tempo so that a preferred tempo setting can be applied by track. Particularly useful if unattended operation is needed.
I didn't find the right solution from the internet.
References:
https://www.native-instruments.com/forum/threads/auto-mix-set-master-tempo.106000/
Case study examples
References:
Case study examples
geposted Sat 11 Nov 17 @ 12:14 pm
Then you're posting on the wrong forum. This is the forum for Virtual DJ software.
For Traktor, go here
geposted Sat 11 Nov 17 @ 12:22 pm
I don't know what to say. Please follow the link posted above, thank you.
Locked for being on the wrong forum by AMAHM
geposted Sun 12 Nov 17 @ 7:53 am
