Topic: Vdj logo and album cover art.
After years using vdj7 without any issues, I decided to upgrade my controller
to a Hercules jogvision. This meant I had to upgrade my vdj to 8. So I'll getting used
to both upgrades. Before it was easy to not display the album cover art on the browser. I can't figure out
how to remove this option now. Also the VDJ logo sits on top left corner, blocking the track info on deck 1
I do have the lifetime version and have found the settings so it does not display on the video window.
but cannot remove it on the skin. I'm using the karaoke scratch skin.
geposted Tue 21 Nov 17 @ 8:57 pm
I don't know what the lifetime version is, but if you have the Pro or controller version, you should register and log in so it shows that you are not a home user.
here is the manual have a look through the browser section https://virtualdj.com/manuals/virtualdj8.html
you may want to have a look at all of it since you are new to 8.
I bet he is running on the 30 day demo right now.. probably have to register when it runs out.
