I have purchased the virtual dj 8 timecode vinyl and trying to hook up with my turntables and rane 57sl mixer. It will not connect. Is there something that I need to do other than buy a newer mixer? haha.
geposted Thu 23 Nov 17 @ 12:56 am
see if this manual helps https://virtualdj.com/manuals/hardware/rane/ttm57mk2.html
geposted Thu 23 Nov 17 @ 1:26 am
The 57SL is not natively supported (the above manual if for the MKII), but you should be able to use its sound card and all its ins and outs.
We dont have the unit but in the past we tried with a couple of users and found out that it works fine with Windows but with Mac OSX, we could only use 1 Input for DVS.
Perhaps you could try all of the possible Input pairs from the Audio Setup of VDJ and all the Input sockets of the mixer and see from which ones you can get the TC signal.
geposted Thu 23 Nov 17 @ 3:24 am
