Topic: Hercules RMX 2 micophone volume.
Will you please map VDJ 8 to control the microphone volume on the Hercules RMX 2. Thanks much.
geposted Thu 30 Nov 17 @ 9:08 pm
from the manual
Hercules RMX2
When the Microphone is enabled, the input will be then routed though the Master Output of VirtualDJ as well. Note that the Mic Volume knob of the Hercules RMX2 will not control the Volume of the Microphone Input of VirtualDJ. The Volume knob of the RMX2 will affect the Mic level on both Master Output of RMX2 and VirtualDJ, however the internal Mic Volume of VirtualDJ will only control what is recorded/broadcasted
https://virtualdj.com/documents/Hercules%20RMX2%20-%20VirtualDJ%208%20Operation%20Guide.pdf
this tells us that knob is hardware only doesn't send data to control anything.
