Discussion about Vestax PadOne
geposted Fri 01 Dec 17 @ 8:55 am
Vestax Pad One Mapper
the mapper assigns decks Left & Right: top pads left deck & bottom pads right deck
bank A : 6 HotCues per Deck
press pads to set hot cue / trigger hot cue (shift will delete them)
bank B Sampler
press pads to trigger samples 1 to 12
by default sampler volume is set 60% (ONINIT)
bank C LoopRool & Loop Set
press & hold Pad to trigger LoopRoll and Loop Set
Pad 1 - LoopRoll 1/8 beat, Pad 2 LoopRoll 3/4 beat, Pad 3 - LoopRoll 1/2 beat, Pad 4 - LoopRoll 1 beat, Pad 5 Loop Set 4 beats, Pad 6 Loop Set 8 beats ;
Touch Pad will move the Loop: rub/slide touch pad "left side" to move Loop back / rub touch pad "right side" to move Loop forward
bank D FX
press & hold Pad to trigger the FX and use the Touch Pad (left/right) to control the Amount Knob
Pad 1 - Flanger , Pad 2 - Reverb , Pad 3 Echo 1/4 beat, Pad 4 Echo 3/4 beat , Pad 5 Echo 1/2 beat, Pad 6 Echo 1 Beat
Enjoy!
PS: remember you can use the "ROLL" (top left red button) and the pads on the Vestax PAdOne to activate FX or LoopRools in vdj8, you have to "TAP" on beat and press the pads to trigger fx looprolls on beat. :)
bank B Sampler
bank D FX
Enjoy!
geposted Sat 02 Dec 17 @ 7:30 pm
