Im using numark party mix with virtual dj, when i plug the output to my speaker, which is a philips home cinema speakers, i noticed that there are slight delay in my headsets and the actual sound coming out of the speaker. What can I do to fix it? I dont find that happen when i plug the output to my little portable speaker. Anyone having the same problem?
geposted Sat 02 Dec 17 @ 2:30 pm
It will be the cinema unit adding delay processing the signal, try output in 2.1
geposted Sat 02 Dec 17 @ 2:33 pm
Sorry Im a newbie started few months ago, could you explain more about what is 2.1?
geposted Sun 03 Dec 17 @ 1:48 pm
2.1 is basic stereo with left and right, with the addition of a channel for a sub woofer. Use that setting.
If you have full surround sound on there will be a delay in the feeds front to back to allow the sound to all arrive at its target destination at the same time.
geposted Sun 03 Dec 17 @ 3:04 pm
