Hi Guys,
I purchased a vdj subscription to use my Pioneer DJ< 450 but there is no support in the software for this mixer. Anyone got a workaround?
geposted Sun 10 Dec 17 @ 2:18 pm
Support in the software? It's a hardware mixer. Use it as a hardware mixer!
Set up the VDJ audio config as 'external mixer' and send each VDJ deck directly to one channel of the DJM-450. Job done.
When you're using real external hardware, there's no need for a 'pretend' mixer on the computer screen - and so there's no need to use your real mixer as merely a controller for the mixer on the screen. Use it as a real mixer, and use a skin that doesn't have a mixer.
geposted Sun 10 Dec 17 @ 2:44 pm
We can help on mapping, will email u details
geposted Sun 10 Dec 17 @ 4:57 pm
