Not sure if anyone has reported this, but I just noticed that "Load Security" is not working. I'm using the mac version 8.2b 3994. I'm not sure when this started. I just casually use my system anymore, so I have just update when I use it.
I have a mid 2009 17" Macbook (I know its old) Pro running Yosemite. I normally casually use it for corporate AV work using a small DJ to Go controller and haven't seem this issue recently. I hooked up my VMS4 (first edition) today and noticed the issue, even though I'm not sure it's related to the problem, but I'd figure I'd mention it.
Kevin
Kevin
geposted Sat 16 Dec 17 @ 2:59 pm
Before someone asks, I did check the settings. I tried the "On" and "Silent", Also, I restarted the software.
geposted Sat 16 Dec 17 @ 3:04 pm
You need to have the on screen deck fader past a certain percentage for security to kick in. Check this as there isn't a volume fader on your controller.
geposted Sat 16 Dec 17 @ 4:52 pm
There are a total of four volume controls on the DJ2GO. Master, headphones, deck A & deck B.
The VMS4 also has volume controls. [edit] actually, if the VMS4 setup in VDJ is using "external mixer" mode then VDJ won't know where the hardware faders are.
geposted Sat 16 Dec 17 @ 4:58 pm
Load security works by detecting if a deck is live on-air or not.
Therefore, if a deck has it's channel fader in closed or almost closed position (0 to 10%) the load security will NOT prevent loading of a new track.
When using an external mixer audio setup there are 2 cases:
a) The connected device provides MIDI feedback to VirtualDJ (fake mixer actions) and
b) The connected device does not provide any MIDI feedback.
On case a everything works as mentioned above (load security works if volume is greater than 10%)
On case b load security is always active since deck volume faders are considered to be on 100% all the time and decks are "always live on air"
geposted Mon 18 Dec 17 @ 7:04 pm
