What is wrong with this macro: "deck 1 is_sync ? deck 1 sync & deck 1 play_pause : deck 1 play_pause" ?
If the deck is not synced ( the else ) don't work.
geposted Sun 17 Dec 17 @ 12:06 pm
Basically this script should do the same regardless of deck state: play_pause
Reason?
deck 1 is_sync ? <--- becomes true when the deck has the same bpm with master deck.
deck 1 is_sync ? deck 1 sync & play_pause <--- Since the deck is already synced, using sync here has no useful function. Therefore it works the same as if it wasn't used at all and results only in "play_pause" being useful.
I believe you're looking for the opposite script:
deck 1 is_sync ? deck 1 play_pause : deck 1 sync & deck 1 play_pause
Or maybe you're looking for this:
deck 1 is_sync ? deck 1 play_pause & deck 1 sync : deck 1 play_pause
The last script has the "sync" and "play_pause" actions in reverse order. This means that the deck will start playing and then sync the phase of the deck if the BPM is similar.
Reason?
geposted Sun 17 Dec 17 @ 6:34 pm
