Hello...I followed all steps for vdj set up with my s3700’s, however, platter will not controlled track. It does spin with the track, bot no manipulation. Do I get platter control with vdj? Is there a reference page for this set up? Any help would be appreciated
Thank you
Thank you
geposted Fri 29 Dec 17 @ 3:43 pm
Did you check here?
geposted Sat 30 Dec 17 @ 3:48 am
Yes....maybe I need to redo. I’ll give it another run. Thank you. If the problem persists, can you think of what else it may be?
geposted Sun 31 Dec 17 @ 3:22 pm
Unfortunately, I don't own this controller, so will not be able to help you. It's the holiday, so maybe someone that owns it will see this and help you.
geposted Tue 02 Jan 18 @ 3:53 am
