Is there a way to add more detail to this? I was curious if it is possible to add path as well?
Thanks,
Todd
Thanks,
Todd
geposted Thu 04 Jan 18 @ 3:34 am
You can change the format in your options browser/TracklistFormat (use the same syntax as skin text-elements).
For example:%author - %title
Fields to use can be found here:
https://virtualdj.com/wiki/Skin%20SDK%20Textzone.html
Another way is possible: you can copy and edit your history-file. Path of your files included there.
geposted Thu 04 Jan 18 @ 5:37 am
Thanks for the info. Still trying to figure out the folderpath but this is cool info. :)
geposted Tue 23 Jan 18 @ 3:25 pm
You can now export your browser view to HTML or CSV. Just select a history file, enable filepath in the browser columns and export.
geposted Tue 23 Jan 18 @ 3:30 pm
