Hi!
If anyone could help me with this, I´´ll be grateful.
I recently subscrived a Infinity PRO license and I´m trying to work with the DDJ SB2 controller.
But I find a issue, the SYNC button only works if pressed after the play button on, is not possible to keep it OFF or ON.
The drivers and firmware are update, the options in VDJ are factory default option.
With the Serato DJ everything works fine, I´ve tried just to filter if it was a controller or software problem.
Is this a mapping problem? Does anyone had a similar problem? How can I work this out?
Thanks for any help.
Regards
Regards
geposted Fri 05 Jan 18 @ 11:07 am
try smart play
FYI you don't appear to have a license what so ever.
geposted Fri 05 Jan 18 @ 11:11 am
What do you mean try smart play?
And about the license, what´s the doubt?
geposted Fri 05 Jan 18 @ 11:22 am
In VDJ sync doesn't lock the tracks. In Serato they get pitch locked together
I really prefer what VDJ does, which is one of the reasons Serato is pretty much useless to me (you can't really turn sync off without jumping the pitch in Serato, so you are stuck in some situations)
Anyway...
So sync only syncs when you press it in VDJ
If your track is not playing it just alligns the BPM's
If it is playing it also alligns the tracks beats
But no locking after that
But you can lock the tracks if you want. That's just not sync.
You can use smart play when starting a track to have i start on the correct time. You can enable that on the little dot next to the sync button
Or you can use Beat lock (or the older pitch lock) function to keep in sync. Beat lock is available on the scratch pane
The best part: If you turn off beatlock after a mix VDJ won't jump in pitch like Serato does. Hallelujah!
Of course you can map that anyway you want in VDJ, including changing the sync function on your controllers sync button
To me it looks like you are a pro subscriber, so that seems fine
geposted Fri 05 Jan 18 @ 12:17 pm
When I posted he was a home user
geposted Fri 05 Jan 18 @ 12:44 pm
I realized that I didn´t had "my account" updated. Sorry and thanks.
geposted Fri 05 Jan 18 @ 1:22 pm
Anyway...
Anyway...
I will try this. Thanks for the infos.
geposted Fri 05 Jan 18 @ 1:23 pm
You inspired me to do a video about this subject:
geposted Sat 06 Jan 18 @ 12:29 pm
