i am using hercules rmx2 skin
how do i add samples to the four pads on each deck please
geposted Tue 09 Jan 18 @ 1:56 pm
It it this skin?
Because then I don't see which 4 pads you mean
Or do you mean the physical pads on the rmx2 controller?
That has nothing to do with what skin you use
That's all up to the mapping
In that case there are several ways.
You can map them to play sample 1-4 of the currently selected sample bank
Or you can map them to play known samples based on names
Or you can map them to play samples based on a path
You do all of them by choosing which button/pad you want to map in settings->controller, and then use the sampler_play or sampler_pad functions to do it
geposted Tue 09 Jan 18 @ 2:36 pm
