This isn't the usual issue I have seen reported. I searched to see if it has come up already. My Mixdeck Quad is set up to use the mixer as an analog device. I know it's not MIDI and that only the side controllers are. It works great with Virtual DJ using the recommended set up. The issue comes when you switch the Mixdeck source while it is connected to Virtual DJ. If you toggle either the left or right deck in the Mixdeck from "MIDI" to either "USB" or "CD Deck" the fader continues to work fine but if you go back to MIDI to use it to control Virtual DJ the crossfader no longer works the same. The volume cuts out when you push the fader to the far side of whichever deck you had swapped over. You lose the full range of the fader. Restarting the controller doesn't fix it only restarting the software so I believe the issue is on the program side. You can be careful and get away with still using the fader but this is a bug and thought I would ask if anyone has had it and what they did.
geposted Mon 22 Jan 18 @ 9:23 pm
