It's not a skin, it's a unicorn
geposted Sun 08 Dec 19 @ 12:12 pm
GREAT !!! I want it too !!!
geposted Thu 21 May 20 @ 11:59 am
I really want this demo skin is there any download link
geposted Mon 25 May 20 @ 10:16 am
Skin downloads are done from within VDJ now. If the skin is not shown there, it's not available.
geposted Mon 25 May 20 @ 10:27 am
The skin has been on virtual dj for 2 months but is not approved because character size anomalies, various inaccuracies ect have been verified.
If it is tested on a non-ultrawide monitor, anomalies obviously occur.
They probably did not understand that it is an ultrawide skin ...
geposted Fri 26 Feb 21 @ 3:35 pm
Might be ok looking if it on init sets the screen to wide format..
For example 1720x720
extremely few users with ultrawide monitors... so it will be extremely few who can use it as is perhaps ;-) And things like browser font size is set to around 6px or so, so need quite a screen resolution to be able to used it.
What is your screen resolution by the way? Dpi and pixels?
geposted Fri 26 Feb 21 @ 3:52 pm
Added this in your skin for now:
<onload action="skin_width 1720 & skin_height 720"/>
And set it to Pro users only, since it can be quite difficult to use and even find way to change back to other skins with this skin. And requires a very wide screen for practical views. ;-)
Available on site now https://virtualdj.com/forums/239986/Addons/Turntable_Ultrawide.html
geposted Fri 26 Feb 21 @ 4:05 pm
Replaced Rune's add with : <onload action="skin_width 2580 & skin_height 1080"/>
to make it fit in 2xFullHD touchscreens
Added 'move="circ" sensibility="1.33"' after all occurences of 'anglemax="+140"' (normal knobs) and all occurences of 'anglemax="+145"' (fx small knobs) in a way to make them usable with touchscreens
Added breakline="1599" in a way not to resize bottom labels (character size anomalies)
Still one issue : in browser mode dropzone for deck 1 overlaps top folders in folder tree
with this size vinyl is pretty responsive and precise
nice start for a promising demo :)
Tip switching back to another skin : double click bottom right corner resets to default window size
then move window and resize it to keep size registered.
(even the pos and size are registered as per skin/layout, VDJ resizes and move skins either to current settings or to make them fit one display, not using skin saved ones)
geposted Fri 26 Feb 21 @ 8:48 pm
I understand that it takes a huge monitor (3840x1600 is the native resolution of my monitor) but I have specified this several times which is why I have waited so long to publish it.
But many of you have insisted and published it.
I repeat: it takes an ultrawide monitor.
Skin resizing example:
geposted Sun 28 Feb 21 @ 4:59 pm
Thanks Rune
geposted Sun 28 Feb 21 @ 5:12 pm
Thanks Bigbaromilly
Man.. if you could make a smaller size version..I am afraid of messing up my graphics I have standard high Resolution and I am about to get a extra Wide screen but that would be for the VDJ output for dancers to see...I'm sure many would love playing with this ..you are a master Artist with the graphics..beutifull !
geposted Wed 03 Mar 21 @ 2:25 am
After a long time, here we are with an updated version of the demo skin that we will call version 2.
geposted Mon 01 Jan 24 @ 6:13 pm
