Hi, MacBook Air for backup. Installed VDJ8. Copied iTunes from original MacBook Pro. Opened vdj on the MacBook Air then clicked on reload to add the newly installed iTunes and the songs show up but there is an X in every song in the lists.
geposted Sun 11 Feb 18 @ 5:22 pm
Not sure how to delete one of them.
geposted Sun 11 Feb 18 @ 6:16 pm
maybe start with this https://virtualdj.com/wiki/iTunes%20not%20showing.html
you may also check the location of one of the files in the tag editor and see if it seems to be correct
something else to consider https://virtualdj.com/wiki/DRM%20Files.html
geposted Sun 11 Feb 18 @ 6:28 pm
