I know how to organise the FX into different folders in the FX slots but I'd like it so when scrolling FX slot 1 it has it's own folder from FX slot 2 and FX slot 3. This way when using the 'Shift FX On' button. It will only scroll through the 3 or 4 FX we have in that folder, for that slot. Currently if i put all the FX in 3 different folders and scroll through them using the button, it scrolls through all of the FX, as if scrolling the master folder.
Thanks in advance.
Thanks in advance.
geposted Sat 17 Feb 18 @ 6:37 pm
Should be asked in the Wishes forum. But since you are interested in small groups of effects, you could use the 3 FX slots panel and some FX Banks Plugin load scripts to change banks instead of selecting next/previous FX from the list.
https://virtualdj.com/forums/214433/addons/FXBanks.html?page=1
geposted Sun 18 Feb 18 @ 3:15 am
I think that can be scripted, give me the list of fx for slot 1
geposted Sun 18 Feb 18 @ 8:16 pm
I haven't fully decided on each FX slot yet. In slot 1 will feature beat related FX. Using the beat knob (the stepped knob on the FX section of the controller) sets the beats for slot 1 auto. I was going to make the beat adjustable FX slot 3 as the beat knob is right next to it right but it does slot 1 by default. The beats in VDJ GUI is usually knob 2 so remapping the shift knob function do be knob 3 instead of knob 2 is ideal for this slot.
I've remapped an effects_select ? 'distortion' so if the distortion is on, we get control over the bit depth as standard, instead of strength. I prefer it as a crush not overdrive. Even though I've set the colorfx crush to be an option on the filter.
I have a Map I'm really struggling with, if you could help with that i'd really appreciate it. It's related to adding the beat to the Echo Doppler addon. I'll start a new thread for that.
geposted Mon 19 Feb 18 @ 3:05 pm
Should i start a new thread as a request or could this one be moved to there.
geposted Mon 19 Feb 18 @ 3:06 pm
I'll write you an example with 3 fx
geposted Mon 19 Feb 18 @ 5:02 pm
How did you get on? I'll be setting my controller up today to try out some new ideas.
geposted Tue 20 Feb 18 @ 3:34 pm
Pub quiz tonight, I'll have a stab at it tomorrow evening.
geposted Tue 20 Feb 18 @ 10:55 pm
