Hello,
Downloaded for my xdj-rx2 pioneer controller the install_pioneerxdjrx2 file.
When double click, it asked me for the programm to open. Choosed virtual dj but I can't see the mapper afterwards.
Ii used to be xml files, but what kind of file is this and how does it work?
geposted Thu 22 Feb 18 @ 5:43 pm
Normally the file ends with .xml
But this file has no extension
geposted Thu 22 Feb 18 @ 7:20 pm
It should probably be. exe since it gets installed in the correct place.
geposted Thu 22 Feb 18 @ 8:06 pm
Perhaps the installer creates a .dat file in /Devices folder (encrypted Definition file).
But you see the mapping inside VirtualDJ->Controllers tab and you can edit and create Custom mapping files, right ?
geposted Thu 22 Feb 18 @ 10:22 pm
try using chrome to download.
geposted Thu 22 Feb 18 @ 11:12 pm
This. If using latest IE for downloading .exe files will no longer run
geposted Fri 23 Feb 18 @ 1:22 am
Hey guys,
Thanks for all the help !
It was an exe file, after renaming the file it worked.
IF WE COULD SEE THE WAVE FORM AT THE CONTROLLER, THAT WOULD BE GREAT !!!
geposted Fri 23 Feb 18 @ 7:20 am
It's not fully supported yet. That's why features are missing.
geposted Fri 23 Feb 18 @ 8:31 am
Thanks for the mapper.
Please let me know when there is a solution for the grid !
geposted Fri 23 Feb 18 @ 11:38 am
Then it will be officially and natively supported in VDJ - so you wont need a mapping anymore
But with the first XDJ-RX it took about a year to reverse engineer it and breake Pioneers locks on the product
The best thing you can currently do is write/call/post on anything owned by Pioneer and tell them, that as a paying customer you are very unhappy with their choice to lock their product so that you can't get full value out of it. If enough people do that - or if someone takes them to court over it - it may help...
geposted Fri 23 Feb 18 @ 11:56 am
