Topic: Export Playlist
Whats the best way to export a playlist? I found where the playlists come as an m3u file that can be opened in a text file, but that isn't very visually friendly and a pain to export to excel. I also found the history text file, but that seems to only add a song when you play a song in its entirety (i think). Is there an easy way of doing of this?
geposted Thu 29 Mar 18 @ 3:01 am
Select the Playlist or any other folder from the Folders List Browser view.
Open the Browser Options (small dot on the left-side Browser Toolbar - right above the A-/A+ buttons)
Choose ..Export Browser view
Select the CSV file type, provide a name and Save it.
You can then open Excel and import the saved CSV file
Keep in mind that VirtualDJ will export all the visible fields that you have in the Songs List of Browser, so you may need to add or remove some of them if you only want certain fields/columns, but of course you could handle this from within Excel.
Related Manual link: https://virtualdj.com/manuals/virtualdj8/interface/browser/toolbar.html
Thank you so much! Can't tell you how long i tried to find this.
