Rune, it's probably the configuration in the virtual dj set-up. Because when i play deezer or spotify with my cellphone connected with the Bluetooth speaker the sound is very good. Can you tell me witch set-up is the right one in the audio configuration set up? Should i take "only speakers" for exit, "computer audio" for hardware and then the Bluetooth speaker as master? Or is this configuration wrong?
geposted Wed 19 May 21 @ 1:40 pm
As long as the speakers are set to master, both ways should be fine...
What you can try is opening VDJ settings, and set latency higher, try 512 as value.
Maybe its the buffer on the Bluetooth speaker driver that is running out, that will sound a bit distorted, pops and clicks
geposted Wed 19 May 21 @ 2:08 pm
Ok Thx...👍
geposted Wed 19 May 21 @ 3:42 pm
