Can you merge databases if you have changed the path of where the songs are stored? I'm rebuilding my laptop with a 1tb drive. I have moved songs from my old internal hard drive, as well as 3 external drives into one, cohesive spot. From what I've read, I'm not sure it is possible.
Are there plug-ins that might help? Any info would be greatly helpful!
geposted Wed 11 Apr 18 @ 1:24 am
If you plug in the drives you are currently using then use the copy feature from within VDJ browser then it should add those tracks to the database on the new drive.
geposted Wed 11 Apr 18 @ 5:29 am
Dang! Too late for that. Already copied the songs. Hoping someone can help me!
geposted Thu 12 Apr 18 @ 1:42 am
Delete them, and copy them again...
Or you have to edit the database files manually with an editor. But unless you really really know what you are doing... just copy them again.
geposted Thu 12 Apr 18 @ 7:19 am
