If you buy the home version of virtual dj for the mix track controller. Is there a time limit on it and if I wanted to upgrade to virtual dj 8 how much would it cost
geposted Sun 15 Apr 18 @ 7:29 pm
use the drop down menu for controller specific license prices
https://virtualdj.com/buy/
detailed license comparison
https://virtualdj.com/products/virtualdj/comparison.html
geposted Sun 15 Apr 18 @ 7:48 pm
No time limit, it's yours forever, and will work with just that controller for as long as you like.
There's no upgrade path though. Buying a controller license doesn't get you a discount on the full Pro version.
Maybe you should rent the Pro version until you have enough to buy it?
geposted Sun 15 Apr 18 @ 8:14 pm
I was just reading about the LE 8 versions, on another thread, here. You have to log onto the internet once within 30 days of the last time you logged in, or it'll drop your license back down to the Home version. That's assuming I'm remembering what i read, accurately. Regardless, that's just something I read a few mins ago. So, i figured I'd share here, in case it turns out that way.
Anyway, that's all I've got.
Stay classy, People!
geposted Sat 15 Sep 18 @ 3:11 pm
I believe that's the Pro subscription license
That needs to check in every 30 days to see if you are still a subscriber
BTW: The LE version cannot be purchased AFAIK. It only comes with controllers
geposted Sat 15 Sep 18 @ 3:19 pm
