I am trying to use 8 sliders for the master effect on a Denon MC6000MK2 instead of the original 3 sliders on each side, but have no idea how to remap the original mappings to the master channel. This is how slider 1 on deck 1 looks like: (FX1_PRM_1):
var '$fx1' 1 ? var '$fx1multi' ? var '$shift' ? deck 1 effect 1 slider 2 : deck 1 effect 1 slider 1 : var '$shift' ? deck 1 effect slider 3 : deck 1 effect slider 1 : var '$fx1' 2 ? var '$fx1multi' ? var '$shift' ? deck 2 effect 1 slider 2 : deck 2 effect 1 slider 1 : var '$shift' ? deck 2 effect slider 3 : deck 2 effect slider 1 : var '$fx1' 3 ? var '$fx1multi' ? var '$shift' ? deck 3 effect 1 slider 2 : deck 3 effect 1 slider 1 : var '$shift' ? deck 3 effect slider 3 : deck 3 effect slider 1 : var '$fx1' 4 ? var '$fx1multi' ? var '$shift' ? deck 4 effect 1 slider 2 : deck 4 effect 1 slider 1 : var '$shift' ? deck 4 effect slider 3 : deck 4 effect slider 1 : var '$fx1multi' ? var '$shift' ? deck left effect 1 slider 2 : deck left effect 1 slider 1 : var '$shift' ? deck left effect slider 3 : deck left effect slider 1
What should I change to make this the active master effect slider 1?
geposted Sun 29 Apr 18 @ 1:32 am
deck master effect_slider 1
geposted Sun 29 Apr 18 @ 1:48 am
