Topic: Pioneer DDJ RR Sync Button
Hi - Need Help from anyone
How can I make my Pioneer DDJ RR Sync Button to light up when I am in sync mode. Thanks
geposted Mon 30 Apr 18 @ 10:28 pm
try out:
in the key
LED_SYNC
put it
get_beatdiff 0.5 ? on : var 'syncON'
Thanks for taking the time to direct me but can you please send me a diagram/picture how to go about it. I don't want to mess the programming aspect of the software.
Thanks for your help.
He's referring to the controller portion of the settings.
The default skin has a gear located at the top right corner.
https://virtualdj.com/manuals/virtualdj8/settings.html
There you will find the controller tab on the left side.
https://virtualdj.com/manuals/virtualdj8/settings/controllers.html
Select the controller you want to modify. Then, type in a new name to the right and save it. You can always go back to the factory default from the drop down menu. So, you have a way back if your edits don't work out.
On the left side, look for
LED_SYNC
Select it.
Then, to the right, there is a script. Change it to get_beatdiff 0.5 ? on : var 'syncON'
My mapper for the DDJ-RX has var 'SyncOn' set by default.
try out:
in the key
LED_SYNC
put it
there is another command (which I think is better)
n the key
LED_SYNC
put it
is_sync ? on : var 'syncON'
I will try both and let you know.....Thanks guys for your help!!! Love VDJ software.
Thank you guys... the sync button is working great!!!!
Finally, which code did you use?
Do you have the skin for Pioneer DDJ -RR, can I have a copy . . .
I use the one below.
n the key
LED_SYNC
put it
