Topic: Script School - Page: 47.55
Hi
I'm trying to map the left and right EQ_HI controls on a z2 to make it 4 deck compatible.
both left and right high EQ appear to activate the same midi control script. This is not a problem when it is calling eq_high (as it can determine whether it is left or right), however when I specify deck left eq_high, which swaps between A & C , the right high EQ knob also only works on the Deck A & C. eq_high on its own can determine the context somehow.
1) how is it context sensitve when the mapper appears to indicate it calls the same script.
2) how can I correct my code to allow the left high EQ to call deck left eq_high and the right EQ knob to call deck right eq_high ?
Thanks
In 4 decks controllers you have a button to select between 1-3 decks or 2-4
need one button for make change in each deck
Like
toggle "$deck13"
and other like
toggle "$deck24"
in your knob have to question this variable
eq_high left
var_equal "$deck13" 0 ? deck 1 eq_high : deck 3 eq_high
in eq_hi for right ....
var_equal "$deck24" 0 ? deck 2 eq_high : deck 4 eq_high
hope be useful.
good luck and comment if was useful .
bye
Hi…
wich is different about new script “sampler_rec_delete” and existing script “browser_remove”?
thanks
sampler_rec_delete deletes a sample from the 'recordings bank', not matter if it is visible or selected.
browser_remove removes the selected track from the list currently highlighted in the browser
Hello, i Need help for a Script:
I have put a shortcut on the folder/search Tidal and subfolder Video. this works great and I can search directly. Now I want to call up the shortcut with the keyboard.
Thnax
browser_shortcut X & search
X being the number of the shortcut.
browser_shortcut X & search - this works perfectly.
Is it possible to have the same functionality as the ‘normal’ mp3 search? If there is no track in the database, does it search Tidal first? But just for videos?
hi there,
is there a way to use the script
keyboard_shortcut
anyhow to have the function "playback keys use shift" as in serato?
I'm so used to have it like that.
Aren't you then just mapping to SHIFT+KEY ?
but if you mean to toggle just map shift button to the script you included.
Yes I thought to do whole new mapping. But it would be easier to have the existing mapping overscripted with the shift key.
Hi, is there a script to have sampler quantize? I would samples in beat with the song…thanks a lot
Recording samples follows the loop quantize setting
in drop mode only tempo sync? right?
Yes, indeed for loop mode.
You could create the sample as loop and change to drop in sample editor if you really need quantized start for drops, but probably more rarely needed
Hi, how i can map a controller button to 'stemswap bank' option? my script is:
setting 'stemswap bank' on ? setting 'stemswap bank' off : setting 'stemswap bank' on
but not work
thanks!
indeed there's currently no script to do this. we'll add in the next build.
it will be
sampler_options 'stemswap'
(or
sampler_options 'locked'
to change the lock)
Is there a script to turn the cover backwards?
"& param_invert" this works but not on the cover...
Thanks
No <cover> doesn't offer a direction, and I can't think of any other way to call cover art as a visual
hi!
this script:
sampler_pad_page & param_cast ‘integer’ & param_equal ‘9’ ? action 2 : action 1
not correctly work (play only action 1)
why? where is error? thanks a lot
Hi all. Question. There is a goto_last_folder command. Is there a goto_last_sampler_bank? Or is it possible to implement this function in scripts?
88%
