Another great update guys !
the video skins and shader are great
also been playing with screen grab - also very cool, but have a slight issue , cant seem to get rid of the screen grab box even when its deactivated ?
now lets dig a little deeper into those new features...................
geposted Fri 08 Jun 18 @ 8:13 am
I had the same problem and have for the moment ignored this feature.
geposted Fri 08 Jun 18 @ 8:19 am
well its not just me then !
does work well, just need a minor bug fix
geposted Fri 08 Jun 18 @ 8:24 am
The selection window shows as long as the plugin is selected. If you select a different plugin the selection window will disappear.
geposted Fri 08 Jun 18 @ 8:31 am
Ok got it , makes sense, next issue
I can grab and resize while its active, this causes it to become just a white box, sometime half white, half overlay, turning it off and deselecting then re enabling solves it
I can reproduce here
geposted Fri 08 Jun 18 @ 8:50 am
in actual fact its when you resize from the top left corner
geposted Fri 08 Jun 18 @ 8:52 am
Yeah, once resizing it just stays there until VDJ is exited and appears on top of any window, even when it's deselected and another effect activated.
geposted Fri 08 Jun 18 @ 9:20 am
