I'm not sure if it's not possible as I don't think it's included in the ID3 Tag data, but:
Is there a way to edit a song's playcount attribute using the browsed_song function?
e.g. browsed_song 'playcount' 1 / browsed_song 'playcount' +1 etc.
I essentially want to set pad buttons to increase and decrease a songs play count by 1 if it's possible
geposted Sat 23 Jun 18 @ 1:51 am
So you basically want the play count to be wrong? You want to mark it as played X times even if it hasn't been?
Er......why?
Er......why?
geposted Sat 23 Jun 18 @ 7:05 am
I use rekordbox also as I use CDJ's of a weekend but use VDJ as my primary database.
There doesn't seem to be any easy way to import play counts so I do it manually and I'm looking for ways to improve my workflow
geposted Sat 23 Jun 18 @ 6:42 pm
It's not in the verb list yet (I'll see to that) I'll give the script a poke & prod once I'm home.
And you're correct, it's not a ID3 tag.
geposted Sat 23 Jun 18 @ 7:18 pm
fantastic! nice one
geposted Sun 24 Jun 18 @ 12:50 am
Looks like that field can't be manipulated by script and in all honesty i don't think script is the best way to do it.
RB will have a history M3U,
And you could make a playlist that mirrors your CDs.
You could drop the time needed for a track to be counted as played and skip thru the playlist.
(You could script that bit)
You could include itwish list
geposted Sun 24 Jun 18 @ 10:56 am
you can always just change it in the tag editor :-)
geposted Sun 24 Jun 18 @ 1:14 pm
That's what he does, he's looking for a way for the machine to do the grunt work.
geposted Sun 24 Jun 18 @ 1:38 pm
Will be added to browsed_song in a next update.
geposted Sun 24 Jun 18 @ 2:14 pm
