activated FPS plugin to see what it was doing while playing and then after the first couple of seconds this weirdness started with it
https://youtu.be/xc1pBuNaVk0
https://youtu.be/Jfqj7ti6XYM
geposted Tue 26 Jun 18 @ 2:36 am
opened virtualdj
set video source to None
set video effect to FPS
changed font to make it large enough to see and had same screen weirdness in video output and then browser started looking like this:
mousing over it redraws but then goes back to blank and scrambled when cursor is not over browser area.
geposted Wed 27 Jun 18 @ 12:39 am
from bad to worse.
EA build 4457
all it takes is activating FPS plugin then changing the font to make it large enough to be seen
https://youtu.be/vU-8ha7Pnzg
EA build 4457
geposted Thu 28 Jun 18 @ 10:32 am
the FPS plugin is a user-made plugin that is 7 years old.
It's possible that something is not compatible with the newest systems, and that it has a bug that didn't show before.
(though we can't reproduce the problem you described here)
geposted Thu 28 Jun 18 @ 10:45 am
might be one of those lost causes then.
deleted plugin.
now to go try and track down the other one that made it hang..
wheeee!
deleted plugin.
wheeee!
geposted Thu 28 Jun 18 @ 11:21 am
The FPS plugin was converted to VDJ8 just before 8 came out around 2014 or whenever, by an Atomix employee. There is a thread on it but don't wish to revisit it. I mentioned back then it should not even be in the plugin list because it can cause problems. Was fine for some development cases but that's all.
geposted Sun 01 Jul 18 @ 7:27 am
