Hi All,
I just wondered if this may be due to the latest update? I bought the aforementioned controller and everything seemed fine. I did the update and the box in bottom left had DJ2GO2 in it now only has config 1 in it and not DJ2GO as well. A warning came up last night about no sound card but after trying a few configs the normal one seemed to work but with a set coming up this weekend I really got a panic on. This morning when I tested again, all seemed fine.Does anyone know what this might be? Cheers.
geposted Wed 27 Jun 18 @ 7:31 am
It can sometimes change if you used a different USB port. Just make sure its selected in the sound card drop down and if its working then save the config.
geposted Wed 27 Jun 18 @ 7:53 am
Thanks mate. Just seemed odd that the DJ2GO2 option disappeared on the drop down on bottom right.
geposted Wed 27 Jun 18 @ 8:00 am
