Does anyone know how to get this back or is there another way to create this via the new vdj video skin option? Maybe an XML setting edit? Want to be able to display the Artist, Title and cover art if possible.
Thanks,
Thanks,
geposted Thu 28 Jun 18 @ 10:18 pm
https://virtualdj.com/plugins/?filter=256
If you can't find any that you like, you can download the Title plugin as an plugin as well:
https://virtualdj.com/plugins/?addonid=80812
geposted Thu 09 Aug 18 @ 9:10 am[ selected best answer by Adion on Thu 09 Aug 18 @ 9:10 am ]
patience supposed to be coming back as a addon not sure if it will require a license or not thought.......
geposted Fri 29 Jun 18 @ 12:20 am
I'm also missing this a lot - I used it all of the time, and the new "video skin" is shet. It looks really cheesy.
Edited for language
Edited for language
geposted Tue 31 Jul 18 @ 3:29 am
What build are you using, because there is a title plugin? Activate early access.
geposted Wed 01 Aug 18 @ 6:50 pm
Yes, the Title videoskin requires a license.
On that subject...
Why would you need this when only using VDJ at home, I wonder?
geposted Wed 01 Aug 18 @ 7:14 pm
The new title plug-ins don't render at the bottom of the screen like the old one... Anyone good at editing the XMLs to change the render position?
geposted Wed 01 Aug 18 @ 7:27 pm
Mine does, have you try opening the gui?
geposted Fri 03 Aug 18 @ 7:35 am
I can't find it either and kinda miss it
geposted Thu 09 Aug 18 @ 2:43 am
You can have a look at the new Video Skins that can replace it to see if there's any that you like:
Selected as best answer geposted Thu 09 Aug 18 @ 9:10 am
groovindj quoteOn that subject... Why would you need this when only using VDJ at home, I wonder?quote/
Im not a home user, just made an account to access the fourms, we have it at the company I work at that owns about 50 pro licences
geposted Mon 13 Aug 18 @ 10:12 pm
