Hi since updating to VDJ 2018, I have seemed to have lost the mapping for the mixtrack edge (my second controller). I am concerned that this might have also happened to my Denon MC7000.
Do you know if this is a common problem? will it be fixed?
Thank you
Thank you
geposted Fri 29 Jun 18 @ 7:10 pm
No files are deleted on updating.
Did you uninstall the previous version first perhaps, and accidentally deleted the user data as well?
You can always make a backup of settings and mappers by making a copy of the Documents\VirtualDJ folder.
geposted Fri 29 Jun 18 @ 7:16 pm
Hi, I didnt delete any files or uninstall the other version, as it was an auto update. :(
geposted Fri 29 Jun 18 @ 10:46 pm
