Is it possible to easily correct the beat grid live if it is a bit out of sync?
Some plugins (i.e. SoundSwitch) will use the grid and I noticed that the grid has been off on some songs.
Thank you for the help!
Chris
Chris
geposted Sat 30 Jun 18 @ 9:25 pm
adjust_cbg -1
adjust_cbg +1
map those and test it out should work out
adjust_cbg +1
geposted Sat 30 Jun 18 @ 9:28 pm
the grid adjust padpage has everything to adjust the cbg, even if you don't use it, it still shows all your options.
geposted Sat 30 Jun 18 @ 10:39 pm
Goodness!
Why do I always assume you'll be automatically subscribed to a forum you start or post on.
I am very sorry for the delayed response.
Where is the pad page located that you're talking about? I assume it is not an active page by default, right? Do I have to create it custom?
Chris
Chris
geposted Thu 06 Sep 18 @ 11:13 am
geposted Thu 06 Sep 18 @ 12:56 pm
I'll check that out!
Thanks Phantom!
Any way to permanently change the grid for a track?
Chris
Thanks Phantom!
Chris
geposted Fri 07 Sep 18 @ 12:17 pm
Grid adjustments are permanent.
Only if you re-analyse for BPM the grid will be reset.
geposted Fri 07 Sep 18 @ 12:40 pm
Ok. Great! Thanks!
Chris
geposted Fri 07 Sep 18 @ 1:39 pm
