Hello everyone. I'm using Pioneer DDJ RR now, and there is a problem with button "slip/vinyl" mode. If i press it without "shift" it works as slip mode and red LED is on. But if i press it with "shift" button for vinyl mode, LED doesn't work, so i can't see which mode (vinyl or cd) is active now. I think its problem with mapping, and i have tried to copy settings from "LED_SLIP" (get_slip_active ? blink500ms : slip_mode) to "SHIFT_LED_SLIP", replace "slip" for "vinyl", but it didn't help. And even i delete mapping for "LED_SLIP" completly, the LED indicator works fine for "slip" mode. So i just don't understand, how it works(
geposted Sun 01 Jul 18 @ 9:25 pm
your exact script you tried please.
geposted Sun 01 Jul 18 @ 9:27 pm
I don't have any script for this, i just tred to copy standart settings from "LED_Slip" to "Shift_LED_Slip". Factory settings for "Shift_LED_Slip" is "vinyl_mode". I replaced it for "vinyl_mode ? get_vinyl_active ? blink 500ms : on : off". But i think i'm not even close to the problem, because i think "LED_Slip" is not responsible for actual LED in slip mode, because i deleted "LED_Slip" once, but LED still worked
geposted Sun 01 Jul 18 @ 9:59 pm
get_vinyl_active isn't a script.
put it back to vinyl_mode, and when you press shift & vinyl mode is already on. does it not light up?
geposted Sun 01 Jul 18 @ 10:07 pm
Thats right, Led is not working in vinyl mode when i press shift
geposted Sun 01 Jul 18 @ 10:35 pm
sounds like a defintion file bug (nothing we can do as users) I can't check anything more.
Until one of the hardware devs can confim or deny, I would set a custom button on each deck to
vinyl_mode
as a tempoary fix.
vinyl_mode
as a tempoary fix.
geposted Sun 01 Jul 18 @ 10:46 pm
vinyl_mode
as a tempoary fix.
vinyl_mode
as a tempoary fix.
But it works well when i'm using recordbox, it doesn't matter?
geposted Sun 01 Jul 18 @ 10:51 pm
points even closer to a def file error, if it is an error, it will be fixed soon.
geposted Mon 02 Jul 18 @ 12:30 am
gegenava wrote :
.. And even i delete mapping for "LED_SLIP" completly, the LED indicator works fine for "slip" mode.(
If you delete the action from the LED_SLIP, the LED will follow the assigned action, which is slip_mode, so it will still be on/off depending on the slip_mode (if the SLIP button is assigned as such)
gegenava wrote :
Could be a hardware LED, cant recall and we may have missed something. Please check your email...But if i press it with "shift" button for vinyl mode, LED doesn't work, so i can't see which mode (vinyl or cd) is active now.
geposted Mon 02 Jul 18 @ 11:56 am
I sent you email. The file fixed the problem
geposted Mon 02 Jul 18 @ 8:15 pm
So, with the file i sent you, you are able to map the SHIFT_LED_SLIP led to whatever you want and have it working when SHIFT is pressed ?
E.g. if you map it as .. blink , the SLIP LED blinks only when SHIFT is pressed ?
If so, keep the file i have sent you in Devices folder and will push the fix for next update.
geposted Mon 02 Jul 18 @ 8:26 pm
Yes, if i map Shift_Led_Slip to blink, it blinks only when shift is pressed. Now it works as it should be. Thank you for help.
geposted Mon 02 Jul 18 @ 9:18 pm
