Any help appreciated'
I'm trying to set up VDJ8 with my RZX and Serato timecode. I have followed all instructions, but im getting no input into the timecode setting on VDJ (either phono or usb mode)
It works fine with Rekordbox, I am using a Serato 2.5 vinyl for VDJ. I have tried all the record versions to calibrate in settings, but it still doesn't work. Could this be anything to do with the RZX not fully native yet? Any ideas
geposted Fri 13 Jul 18 @ 10:44 am
MAC or PC ?
Can you post a screenshot of your audio setup, and a screenshot of Pioneer Utility Settings ?
geposted Fri 13 Jul 18 @ 10:57 am
Its on OSX. Utility mode is set to auto.
Weird-I uploaded pictures but they don't show
geposted Fri 13 Jul 18 @ 11:05 am
Utility tool provides misc options like Mixer Mode, and outputs (inputs for VirtualDJ) configuration.
For most part, the RZX audio configuration for timecodes is identicall to DDJ-RZ.
Therefore take a look at this page: https://virtualdj.com/manuals/hardware/pioneer/ddjrz/advancedaudio.html
geposted Fri 13 Jul 18 @ 11:08 am
On your picture, input 3+4 by default is used for a CD player connected on channel 2 (and the switcher on top must be set on "USB" position to let the audio pass to the software)
If you visit the link I gave you above, the correct inputs for timecode vinyl are (by default) 5+6 for the turntable connected on CH3 and 7+8 for the turntable connected on CH4.
Switcers must be set on USB position
geposted Fri 13 Jul 18 @ 11:13 am
Thx Dude-I will take a look through and try inputs 5/6 in a few mins when I can get back at my system =]
geposted Fri 13 Jul 18 @ 11:36 am
Yesss-Channel 7/8 cured it. You SUPERSTAR. Thx Bud =]
geposted Fri 13 Jul 18 @ 11:38 am
