The Remote App conrtoller on my Android will not connect automatically! This can be a pain it will comnect quite easily but if I veiw anything else on my Android Phone and revert back to the VDJ remote app the connection is lost and it will not reconnect until I connect to it at the VDJ8. Connect automatically box is checked, and I use the same ip and Port number!
Anybody any ideas how I can rectify this please?
TIA
Pete
TIA
Pete
geposted Thu 02 Aug 18 @ 2:53 pm
It's similar on iOS. If you leave the app to go to another it crashes out completely.
Good news is there is not going to be a quick fix.
Try a VNC solution instead as they work fine.
geposted Thu 02 Aug 18 @ 3:17 pm
Thanks for that!
Tried that but even with a VPN it still won't reconnect automatically.
It's driving me round the bend!
Help!
Help!
geposted Fri 03 Aug 18 @ 7:10 pm
Do you have Apple Bonjour installed on your PC?
That is the mechanism used to connect automatically.
geposted Fri 03 Aug 18 @ 7:11 pm
I have Bonjour installed windows 10, but it will not find any android device!
geposted Sun 12 Aug 18 @ 10:09 pm
https://virtualdj.com/wiki/Remote%20App%20won't%20connect.html
copy and past address don't click it
geposted Sun 12 Aug 18 @ 10:35 pm
