what are the intervals and what is the lowest
geposted Thu 02 Aug 18 @ 4:03 pm
what are the intervals between each
geposted Thu 02 Aug 18 @ 4:09 pm
Er, your post needs to make sense before an answer can be provided.
geposted Thu 02 Aug 18 @ 5:46 pm
I though there where intervals between each i had a problem some time ago and i was told to go up in my latency from auto and we ended on 512
geposted Thu 02 Aug 18 @ 5:48 pm
It depends on the ASIO driver. That's what provides the opportunity to adjust the buffer size. Some may offer smaller/larger steps between size settings than others. I'd suggest that it's the latency in milliseconds to which you need to pay attention.
10ms is a good number to aim for. It should give good performance but not tax the system too much.
geposted Thu 02 Aug 18 @ 5:56 pm
