Discussion about Karaoke OSD 1 (dark-right)
    geposted Thu 16 Aug 18 @ 3:18 pm
          The karaoke list ,next singer is causing me a problem . i would like to only show 2 singers on list ,which we where able to do in the past. is this likely to happen again soon ,if not i will have to remove list altogether .Please advise asap cheers
    geposted Tue 22 Jan 19 @ 6:22 pm
geposted Wed 02 Dec 20 @ 9:58 pm
          Not sure what you mean by two singers in this context.
In VirtualDJ there is just one field to add singer. And if its more than one, I guess you just want to put both there? Singer: Anna & Mark
But maybe you meant something else ;-)
geposted Thu 03 Dec 20 @ 11:13 am
          Or maybe he wanna display next two singers to come only on the karaoke skin
in which case the skin have to be edited (comment out singers 3..5)
Note: "Singer(s)" can be specified but "Key Change" does not work anymore for some builds and can't display
geposted Thu 03 Dec 20 @ 11:41 am
