WHY
geposted Sat 25 Aug 18 @ 5:04 am
geposted Sat 25 Aug 18 @ 7:25 am
I looked for it for an hour, but I couldnt find the link. The add-ons part of virtualdj does not list it either. Big thanks to you!
geposted Sat 25 Aug 18 @ 5:46 pm
were you looking here on the website or through the interface?
the interface tab won't show it for some reason but if you filter on the website it will.
geposted Sat 25 Aug 18 @ 7:13 pm
FYI if you are running 64bit VDJ it will not be able to locate the 32 bit Milkdrop :-)
64 bit VDJ only finds compatible stuff
geposted Sat 25 Aug 18 @ 8:31 pm
yes, I filtered through the program. I am still running the 32 bit.
geposted Sat 25 Aug 18 @ 10:22 pm
And I found out that I needed to install DirectX for it to function properly. I will say this, I ran the shader last night and did have a glitch or 2, but nothing a restart didnt fix.
geposted Sat 25 Aug 18 @ 10:24 pm
