Anyone having the same compatibility issues using the Numark NS6ll controller? One problem when you boot up the software and then the controller the fader and the channel selectors will not respond. I have to move the A/B selector switches before the fader will show a response. Although moving the fader controller will show on the software using the controller. However, if music is playing for example on channel 1 and the fader is in the channel 2 position music will still stream out if you don't move both switches. There is ghosting on the pitch controls at times. The pitch control is needs to be manually adjusted from the software and then you must reset both hardware and software. There just seems to be intermittent software glitches. Is this the instability of Virtual DJ software?
geposted Sun 26 Aug 18 @ 2:17 pm
