HI I'm using Numark Mixquad with virtual DJ8.....my audio setting IS OUTPUT : Speaker!/ headphone CARD : NUMARK MIXDEC QUAD INPUT: nothing
the problem is every time I put a song on either deck the song does not automatically go in my headphones I have to press the headphone Button on my Mixdeck quad.. to ear the song...…...very annoying.....
thanks
thanks
geposted Fri 28 Sep 18 @ 9:05 pm
Erm.....pressing the cue button to enable cueing is a perfectly normal, standard operation for DJs/on DJ equipment.
geposted Sat 29 Sep 18 @ 8:01 am
Erm... automatically switching the cue channel is also standard operation for VirtualDJ (when the autoHeadPhones and pflOnSelect options are on)
Note that it only automatically switches as long as only one channel's pfl is active. When you manually activate it on both decks it will no longer automatically switch, and you have to make sure that only the active deck has pfl enabled before loading the next song.
geposted Sat 29 Sep 18 @ 8:27 am
I need the software pls mine crashed
some one help me
some one help me
geposted Sun 24 Feb 19 @ 12:17 pm
