found this crash bug. please fix
vdj: 8.3 b4592
open "settings"
click on "options"
click on "reset to factory default"
click on "yes"
vdj will shut down no matter what. even if there is music playing.
.. i know it does what it says it will do. but it should not shut down no matter what. unless the user decides to close vdj.
vdj: 8.3 b4592
open "settings"
click on "options"
click on "yes"
geposted Wed 10 Oct 18 @ 6:22 pm
That's what it's supposed to do. How can it reset the software if it's still running?
geposted Wed 10 Oct 18 @ 7:17 pm
it's not resetting the software, it's applying default values to settings.
geposted Thu 11 Oct 18 @ 5:12 am
When I read “reset to factory default” this is precisely what I expect it to do.
geposted Thu 11 Oct 18 @ 1:43 pm
