The "pro trail" had ran out on this device awhile back and due to the application failing to ever start I decided that I wouldn't be buying any "license". I do remember registering the LE license, and it even showing a serial number under the license & user account menu, and I most certainly remember not having a 10 minute interruption. Could factory resetting be the culprit to this? Is there a way to retrieve this?! As for the LE Installation card I have no idea where that is.
geposted Sun 14 Oct 18 @ 11:34 pm
The VirtualDJ LE Card included in the box of PartyMix didnt have any serial for VirtualDJ printed. The LE Card had just some basic instructions for a registration procedure to get the VirtualDJ LE Keycode from numark.com
So login here https://www.numark.com/my-account/product-registration with your numark.com account and you should be able to retrieve it.
And here is a video showing steps https://www.numark.com/product/party-mix
If for some reason you cant retrieve it, then you should contact Numark Support to get further assistance. Since your VirtualDJ account (the one you used to post here) doesnt seem to have any registered LE Keycode, then we can't help much.
geposted Mon 15 Oct 18 @ 1:03 am
Ringrazio per le vostre attentissime Notifiche,vorrei acquistare una consolle esterna compresa di ogni strumento effect e altre opzioni per poter registrare con ottimi risultati audio,so' che queste applicazioni esterne filtrano in uscita in alta qualita' e mi piacerebbe poterne vedere qualcuna su vostro consiglio..il problema e' che io non avendo un conto informatico cioe' una prepagata o altri tipi di pagamento web,non posso informarmi piu' di tanto perche' anche nelle promo chiedono estremi bancari e codici da prepagata,posso solo fare un pagamento al momento della consegna se non e' troppo costosa...RINGRAZIO
vostro utente Beppe (Bp°)
geposted Wed 31 Oct 18 @ 11:36 pm
This is the international forum if you are not an expert in English
and want to write in your language visit the Italian forum here
http://it.virtualdj.com/forums/8/Italian_Forum.html
Questo è il forum internazionale se non sei esperto di lingua inglese
e vuoi scrivrere nella tua lingua visita il forum italiano al link sopra
geposted Thu 01 Nov 18 @ 9:08 am
