Hey
I have Pioneer ddj-1000 and as soon as I connect my Mac to the device, the virtual can not connect properly, it just controls the buttons but does not release sound in main
I have an Apple computer
Thanks in advance for the helpers
geposted Thu 18 Oct 18 @ 11:47 am
Most controllers don't need drivers on Macs, but, Pioneer do.
Have you installed the drivers from the Pioneer website?
It has been plug 'n play since March, build b4204.
geposted Thu 18 Oct 18 @ 12:06 pm
Yes I installed and still does not work for me, what to do?
geposted Thu 18 Oct 18 @ 12:49 pm
Did you allow drivers to be installed properly? Check the Security tab in System Preferencies
Can you post a screenshot of the Audio Setup of VirtualDJ ?
Also check if the Pioneer audio device is selected by the OS as default (and select your built in instead), there is a chance some other application running at that moment taking exclusive control of it
geposted Fri 19 Oct 18 @ 12:13 am
geposted Fri 19 Oct 18 @ 9:08 am
