Hi Everyone. I create this post after searching and not founding something relative to the problems mentioned before.
first the video. when I want to put a video from master source on the skin there is a line on the right side across the screen but also if you increase the size it has a distortion. also when there is no video you can not set a timer between transition.
Second the sampler. this is been a long time ind still the problem. since nowadays most of the controllers come with 8 pads for side, you guys need to update this area by separate 8 sampler for side like a hot cues. because you can play on left side the 8 samplers normal but the other 8 from right side repeat the sampler 5 to 8 example if you press sampler 10 it will play the sampler 6 but also it will light up the sampler 14
And Final the keycue, the key cue -3 is not working and Im sure is an internal problem because also on the controller is not working.
thank you all and hope this bug you guys fix soon I left some capture so you can see it
geposted Sun 28 Oct 18 @ 1:07 am
This is a skin problem and it is recommended that you replace other skin first.
geposted Sun 28 Oct 18 @ 1:30 am
it is not the skin it does on all the skins even the controller that i have that's why I chose vdj skin because I was pretty sure that you guys said that, and to probe it i will download another skin and post pictures
geposted Sun 28 Oct 18 @ 1:55 pm
I got something similar when I play a video sampler on my main screen appears as transparent meanesn I have 2 videos playing at the same time the original mp4 from the video plus the drop
geposted Sat 29 Dec 18 @ 4:19 am
