Forum: Addons
Topic: Ableton Link - Page: 1.6
djdutschi wrote :
klausmogensen wrote :
djdutschi wrote :
Adion wrote :
It is built in, so there is nothing to download
When it is Built In , why Users must install it?
When it is Native Plugin , integrate it in VDJ ;-)
I think that's a new standard
The same goes for a few regular effects like Mobius and Instant Doubles. You "install" them on the extension page even though they are already integrated in VDJ
I think it's because there are so many of them by now that leaving some of them out of the default list, and letting you "install" them yourself if you want them, is an attempt to keep everything a bit more clean
And probably more than 90% of all VDJ users will never use Ableton Link, so there is no need for it to be in the default list of effects (and think about the questions if it was always the top-of-the-list effect: "When I click Echo I can hear echo, but when I click Ableton Libk nothing happens. Why?". "Well, it doesn't do anything by itself. You preferably need 2 laptops, a correctly setup network, and 2 pieces of software, one of them bing VDJ, and you then need to..... " Too Much hassle)
Just my guess :)
New Standart? Sorry must laught :-D
1. The Extensions Page in the Prog. Settings is not actual sorted , when Users sort by Newest then other on Top.
2. The Apleton Link is from 2015?? Never before seen it....
3. Where do you have seen a Instand Doubles FX , I don't see this.....
4. The Mobios FX I have long time installes , It was integrated automatical , I don't must download It ... (It was Native FX from first Time) ;-)
Only the Apleton Link I must install from the Extensions Page there...
I don't like the Extensions Page , like the normal Way to download and install Plugins..
Greatings Dani
By new standard I mean that you use the extension page to show/hide features that are already included in the software.
That has started very recently
debtman3535 wrote :
When enabled and blending a new song, the incoming song's BPM drifts badly. I'm not sure if it's a result of the DMX interface I'm connected to via Ableton Link, or an issue with this plugin. No BPM drift when Ableton Link is disabled, however.
I have the same problem....I using ableton link to sync with lightning software on Virtual DJ the effect is installed on the master....
What I saw is that Ableton Link says that 5 Apps are connected....but I only have the master in virtual dj and the lightning app....
Could you please fix this ?
Which lighting app do you use?
Hello :),
I am having a problem when using iMachine 2 app on my iPad alongside with VDJ last update (windows 10) with ableton link turned on on both (on VDJ I've turned it on from the master effect list), but the problem is that iMachine 2 is only syncing with a playing deck 1 (if deck 1 is stoped it will not sync at all) even if the masterdeck selection is set to auto, so when deck 2 is the master, iMachine 2 won not sync with it (even when playing).
Then I've tried to enable Abletonlink on all decks but then the problem is that all decks will behave as if the pitch lock is on, which I don't want. Isn't it supposed to sync with the master only?
Thank you
Why don't you want to activate it on the decks you want to sync? That's how it's supposed to be used
I use a 4 decks skin and I use almost all the decks. If every time I want Ableton link to work on a deck I have to turn it on, so I will face one of two things:
1- I have to keep turning on and off Ableton link on each deck I want to use which is annoying.
2- If I don't want to turn it off again on any of the 4 decks it will lead me to have 4 decks with Ableton link enabled which I really don't like since it behaves just like the beat lock enabled.
But if it is supposed to work for a single deck why is it included in the master effect list?
Thank you for your reply :)
In addition to that, all the decks in VDJ follow the master deck (Master deck automatically assigned), why Ableton link is following only deck 1 even if it is not the master? don't it let you think there is a plugin bug? I am only thinking out loud because I don't know too much about plugins creation and coding :).
Ableton Link is also used by some lighting software. In that case it could be used from the Master list as a one-way sync from VirtualDJ to the lighting software (but not the other way around)
yes good evening, i really would like to have a discussion here about whether or not follow the master with the keys, and why isn"t the master in 2020 synchronised with the master and yet you can not change , it because he do not follow up, the nightstreamer
Hello , God bless you all.
Is there any plan soon to update the ableton link feature? At least to make it follow the master tempo, since when it is enabled in the master effect section it only follows deck 1. Thanks :)
Think it follows master on master ..
And there is an explicit button when on master. in the Ableton Live plugin settings, called "master" for one way to DMX software if needed
Unfortunately, when the plugin is active in the master effect section, it only follows the Deck1, so if you switch to deck 2 and play a song and try to change the bpm my iMaschine app will not follow deck 2 even if it is the master deck. The Ableton link should follow the Master bpm, and Master bpm should mean that read from the master deck.
This is the description of ableton link plugin from Ableton site: Hop on to the same network and jam with others using multiple devices running Link-enabled software. While others play, anyone can start and stop their part; or start and stop multiple Link-running applications at the same time. And anyone can adjust the tempo and the rest will follow
but sadly it is not the case with VirtualDJ. Or maybe I am doing something wrong.
I am using VirtualDJ with iMaschine2 app on my Ipad, so I am trying so link the app with the master tempo of VDJ and vise versa. Thank you
Update now it works better when I switched off the Link plugin in master effect section, and only switch it on for deck 1 & deck 2, now I can change bpm on whatever place and all is syncing together,
but first when the master ableton link is ON in addition to Deck 1 link and deck 2, the bpm is stuck on a fixed value that I couldn't change on vdj, only in iMachine 2 app.
So now it works better.
The plugin doesn't seem to work reliably. Sometimes it doesn't sync up with another app, when that app was running first. While it does if the other app is started later, or restarted. Sometimes it's even required to restart Virtual DJ before it will sync again.
And the issue in this isn't the other app, as it works fine with other ableton enabled DJ software, such as Serato. Both when starting it before, and after.
I haven't experienced that. Connections can be lost, of course
But VDJ always shows how many other Ableton Live instances it's connected to, so it's easy to see
Bonjours,
Voici mon problème!
Vurtual dj et abelton sont link mais je n'arrive pas à sortie le son de ableton sur une platine.
Pouvez vous m'aider? Merci!
Yaya Lamuerta wrote :
Bonjours,
Voici mon problème!
Ableton link is to match the tempo not to play sounds from ableton through vdj
